Over the past several weeks, the new Boardsort headquarters has transformed from a concrete slab into a towering steel structure, and we’ve officially reached one of the most exciting stages of the entire build: the full erection of the main frame. The “big iron,” as the crews call it, is now standing proud—rigid frames bolted into place, purlins and girts tied across the bays, and bracing stretched tight to hold everything square. Watching these massive steel columns and rafters go up has been nothing short of incredible. Each frame begins with the columns being set on anchor bolts embedded in […]
