Today marks one of the most exciting milestones yet — the concrete for our footers has arrived and been poured. After weeks of digging trenches, setting rebar, and preparing the base with gravel, it’s finally time to put solid strength into the ground. From overhead, you can see the pump carefully laying concrete into each trench, filling in the network of rebar and cutouts that will soon cure into the foundation of the building. Known as a truck-mounted boom concrete pump, it uses a long, hydraulically controlled arm to deliver concrete with pinpoint accuracy across the entire footprint of the […]
Rebar in the Hole.
The next stage of construction has officially begun, and with it comes a new look for the site. Rebar and gravel have arrived, marking the final steps before concrete is poured into the footers. From above, the pattern of the excavation cutouts is striking — a repeating series of trenches and squares that hint at the structure to come. Take a closer look and you will see that the rebar is already in place, especially around the corners where the building will need the greatest strength. These steel reinforcements will give the concrete footers the rigidity needed to hold up […]
Foundations of the Future.
After all the work to fill, compact, and level the site, it might seem strange to be digging back into the dirt again. But this time, the digging has a purpose: we’re preparing to pour the footers and pylon bases that will carry the entire weight of the new facility. The process begins with carefully carved trenches and enormous pylon cavities. Into these, crews will place rebar and then pour 8 inches of solid concrete. These massive bases will anchor the structure, distributing the load and ensuring long-term stability. If you look closely at the size of the pylon cuts, […]
The Secret Life of a Stormwater Basin.
One of the less glamorous but absolutely critical parts of building a facility like ours is dealing with stormwater runoff. Local building codes require that new construction capture and control a certain volume of rainwater on site rather than simply letting it rush into the city’s storm sewers. The idea is to prevent downstream flooding and to filter out sediment and pollutants before the water leaves the property. To meet those standards, our plans include a carefully engineered detention basin system that looks simple at first glance but is actually quite sophisticated. Instead of just digging a large hole, the […]
From “Hole” to “Whole”.
The big hole is no more. After 207 truckloads of soil, countless passes of the roller, and precision grading, the site has been filled, compacted, and rolled flat. Using a laser and receiver mounted on the dozer, crews ensured the surface is level to the inch — a crucial step in getting everything just right before the next phase. Building codes also required the addition of a compacted fire lane around the entire perimeter of the site. This ensures emergency access and adds another layer of stability to the build. With this step complete, the site is ready for what […]
It’s a Dirty Job But We’re Glad Somebody’s Doing It!
Digging the big hole was only half the job — now comes the task of filling it back in. To build up a strong, stable base for the new facility, we brought in 207 truckloads of clean, high-quality soil from just eight miles south of the site. For two days straight a fleet of diesel drinking wagons of steel hauled fresh fill back to the boardsort.com site. Truck after truck rolled in, each one dumping its load before crews spread the soil evenly across the footprint. Once the soil was down, the compaction began. A massive vibrating roller — tipping […]
“Hollowed” Ground
Here it is: the giant hole where our 18,000+ square foot building will soon stand. To create this space, we removed more than 54,000 cubic feet of topsoil and clay — a staggering amount when you stop and think about it. That huge hauler parked in the middle of the site gives you a sense of scale; this isn’t just a foundation, it’s the start of something massive. But none of that material went to waste. Instead of hauling it away, we put it to work right here on the property. The soil and clay will be shaped into natural […]
